ONors
6 years agoWhere is the HTML-report for altera_fir_compiler_ii documented?
When generating an altera_fir_compiler_ii a HTML file is produced. This HTML-file appears to be some kind of report or documentation. There is a name-value list called Parameters. For most of the nam...
CheepinC_altera
6 years agoHi,
thanks for your update. I am able to view the generated html after creating a project and instantiate the FIR II IP. As I look into the html, it seems to be IP internal parameters which define the instantiation. Since it is for IP internal usage, user can ignore it. User should focus on the parameters available from the IP Editor. Just would like to check with you if you encounter any problem during set up in IP Editor? Or if you have any specific inquiry related to any parameter in the IP Editor so that I could help to further clarify.
Thank you.
