ONors
6 years agoWhere is the HTML-report for altera_fir_compiler_ii documented?
When generating an altera_fir_compiler_ii a HTML file is produced. This HTML-file appears to be some kind of report or documentation. There is a name-value list called Parameters. For most of the nam...
CheepinC_altera
6 years agoHi,
As I understand it, you have some inquiries related to FIR II generated file. Just would like to check with you which Quartus version and device are you using? As I tested generating FIR II with CV in Q17.0Std, I do not observe any HTML file generated in the HDL folder. Would you mind to further elaborate on the specific HTML file that you are referring to?
Thank you.
