IXi00
6 years agoWhere can i get Quartus Programmer software v14 for 32 Bit?
My Device could not support 64 BIT
Vicky1
6 years ago"Hi Vicky, I tried the link that you provide, It's for 64 Bit.
The reason why i need version 14 and above is because i am using MAX 10 FPGA where only version 14 and above able to support" - - - - - -
- On Altera's info page: https://www.altera.com/support/support-resources/download/os-support.html From the table footnotes. I highlighted a couple of items. starting with acds v14.0, intel fpga software only supports 64 bit versions of the os listed in table 1, unless specified.
- The 32 bit library files are required to run the software on Linux* 64 bit platforms.
- Windows 8.0 only.
- Both 32 bit and 64 bit are supported.
- Only KDE desktop manager is supported.
- 32-bit standalone programmer is only supported in standard edition.
So in your case MAX 10 device only available in Q14.0 onward versions so you need to use 64 bit operating system to use MAX10 devices
Alternatively if you use Quartus Standard Edition (PAID version) of the tools it appears a 32 bit version of the standalone programmer tool is supported.
Please help me to close this case.
Thanks for the patience & cooperation.
Vicky
