LWANG128's avatar
LWANG128
6 years ago
When I run simulation of a rapidio qsys,there is a error occures,but why it is happening?
When I run simulation of a rapidio qsys,there is a error occures,as this:
Info: Start Nativelink Simulation process
Error: You did not generate the simulation model files or you generated the IP file using an older version of MegaCore which is not supported by RTL NativeLink Simulation
Error: Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly
Error: NativeLink simulation flow was NOT successful
  • Vicky1's avatar
    Vicky1
    Which Quartus edition & version are you using?
    Have you tried by regenerating the IP & simulation model for that IP in presently used quartus tool?
    Could you provide *.qar project file ('Project ' Menu->'Archive Project') replication purpose?
    Vicky
  • Vicky1's avatar
    Vicky1
    May I know any update?
    Vicky
