When I generate the CIC filter, Quartus does not generate the CIC compensation coefficients. Has this function been removed?
As I understand it, you have some inquiries related to compensation coefficients generation from CIC filter. To ensure we are on the same page, would you mind to further elaborate on the specific file that you are expecting? As I look into the user guide, seems like I am unable to find specific information on compensation coefficients generation apart from FIR Filter Compensation Coefficients.
Just would like to check with you if you are able to generate the file previously with other Quartus version?
Thank you.
- EDavi216 years ago
@cheepinc_Intel , Thank you for your reply! I was actually referring to the FIR Filter Compensation Coefficients, for my generated CIC. This is my first time working with Quartus IP, so no. However, I was able to generate the files by clicking "Example Design" which I tried by happenstance after posting this question.
Thank you
