JPott5
6 years agoWhat is the simplest way to implement a memory interface on the MAX 10?
My FPGA design reads serial data from a number of serial interfaces, packages it up and needs to make it available to a separate micro controller via an 8 bit parallel bus. What is the best way to ...
BoonT_Intel
6 years agoHello Sir,
Do you mean memory interface like DDR3, DDR2? If yes, you may refer to the EMIF User guide to the implementation.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_emi.pdf
By the way, if the require memory density is not much, then you can consider the on-chip memory.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-memory.pdf
