sbala31
6 years agowhat is the option to initiate the DDR3L calibration? how long it will take to complete the calibration?
we are trying to simulate(functional) ddr3l controller ip with micron memory model. After reset release, we are able to see PLL lock and memory reset release. we are expecting calibration/initializat...
sbala31
6 years agoHi,
We tried with example design and found that it is working(simulation passed).Also we tried to implement the same timing and same memory model(from the example design) for our test environment and found that there is no transactions(initialization) from the controller to memory after memory reset release. Whether any options are there to start the calibration?
BoonT_Intel
6 years agoif the options is work in example design. Then it should work in your test environment as well. Please check the setup between your environment vs example design.
