what is the option to initiate the DDR3L calibration? how long it will take to complete the calibration?
Hello, Micron memory is supported from hardware perspective. However, please double check emif estimator for the memory scheme that you want to use.
At this moment, I will suggest you to purely run the example design simulation and see if it work in your simulator first. You can generate the example design using your targeted micron memory settings - eg. enter all parameters into the IP GUI based on the targeted micron memory, then generate the example design. Follow the step provided earlier and run the simulation.
We tried with example design and found that it is working(simulation passed).Also we tried to implement the same timing and same memory model(from the example design) for our test environment and found that there is no transactions(initialization) from the controller to memory after memory reset release. Whether any options are there to start the calibration?
- BoonT_Intel6 years ago
if the options is work in example design. Then it should work in your test environment as well. Please check the setup between your environment vs example design.
