what is the option to initiate the DDR3L calibration? how long it will take to complete the calibration?
Hello, Micron memory is supported from hardware perspective. However, please double check emif estimator for the memory scheme that you want to use.
At this moment, I will suggest you to purely run the example design simulation and see if it work in your simulator first. You can generate the example design using your targeted micron memory settings - eg. enter all parameters into the IP GUI based on the targeted micron memory, then generate the example design. Follow the step provided earlier and run the simulation.
We are not seeing any ddr initilization / calibration from controller. if ddr controller doesnot support micron mem model in simulation, then we can expect calibration failed, but here there is no toggling on cas ras we cs (for ddr initialization)
