17 years ago
What is Altera library for 16 bit Shift Register LUT with Clock Enable
I want to change from Xilinx desing code to Altera.
But, I don't know what is altera library for following two xilinx library.
If you konw it, let me know.
1) 16 Bit Shift Register Look-Up-Table(LUT) with clock Enable
(http://toolbox.xilinx.com/docsan/data/alliance/lib/lib10_10.htm)
2) 2 to 1 Multiplexer for Carry Logic with General Output
(http://toolbox.xilinx.com/docsan/data/alliance/lib/lib7_33.htm)
    For the first one, there isn't an exact replacement, you may design a wrapper to port existing code, if necessary. The second one is a very basic element that wouldn'n be instantiated directly to my opinion. But you possibly can find a replacement in primitives library.
    I noticed, that Xilinx mentioned inference recommended with both components, in other words, they assume that you let the HDL compiler choose a suitable library component. In this case, you don't have to worry much how to port the code to another FPGA family.
    I strongly agree with FvM. These components can all be inferred, and the coding is much easier and more understandable. Fot the sift register, there is a megafunction call altshift_taps that makes shift registers out of memories. I don't recommend instantiating that either, but letting Quartus infer them. If you go to Assignments -> Settings -> Analysis & Synthesis -> More Settings -> Auto Shift Register Replacement, which is set to Auto. On some X designs I've converted where the user instantiated this, I put in an RTL model, let Quartus figure it out, and ended up using less logic because of it(but a little extra memory.) Here's a model that should help:
    module SRL16E(Q, A0, A1, A2, A3, CLK, D, CE) ;
    input A0, A1, A2, A3, CLK, D, CE;
    output Q;
    reg [15:0] shift_reg;
    reg Q;
    always@(posedge CLK)
    begin
    if (CE)
    shift_reg <= {shift_reg[14:0],D};
    end
    always @ (A3 or A2 or A1 or A0 or shift_reg)
    begin
    case ({A3, A2, A1, A0})
    1 : Q = shift_reg[1];
    2 : Q = shift_reg[2];
    3 : Q = shift_reg[3];
    4 : Q = shift_reg[4];
    5 : Q = shift_reg[5];
    6 : Q = shift_reg[6];
    7 : Q = shift_reg[7];
    8 : Q = shift_reg[8];
    9 : Q = shift_reg[9];
    10 : Q = shift_reg[10];
    11 : Q = shift_reg[11];
    12 : Q = shift_reg[12];
    13 : Q = shift_reg[13];
    14 : Q = shift_reg[14];
    15 : Q = shift_reg[15];
    default : Q = shift_reg[0];
    endcase
    end
    endmodule
