What clock sources are allowed for an EMIF reference clock?
I need to generate a 200MHz reference clock for an LPDDR3 EMIF. If I don't have any convenient clock available, how can I generate it on chip? There seems to be an issue with using a PLL output as the reference source of an EMIF.
The Altera-ese that I get in the error description is not particularly helpful. Does this signal have to come externally, or can I generate it somehow internally.
Arria 10 10AX022C3U19I2SG
Quartus Pro 21.3.0
EMIF 19.2
- AdzimZM_Altera
Hi KCMurphy,
The EMIF IP need to be driven from a dedicated clock source.
It's cannot uses the internally generated clock to drive the logic.
Adzim
- KCMurphy
And that dedicated clock has to be in the same bank as the EMIF block?
- AdzimZM_Altera
Hi KCMurphy,
"And that dedicated clock has to be in the same bank as the EMIF block?"
- Yes it's must in the same bank as EMIF block
Adzim
- AdzimZM_Altera
We do not receive any further response regarding to this topic. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
