BIdro
6 years agoWhat are the important settings for SDI-SD standard video communication? I use the IP-SDI-II up to SDI-HD and it works properly, but it does not work with SDI-SD. How can I generate a correct differential signal for SDI-SD standard?
The IP-SDI-II supports SDI-SD standard but It uses a 148.5 MHz clock signal as reference. It oversamples the data because the correct frequency should be 13.5 MHz. I use an interface component that e...
CheepinC_altera
6 years agoHi Bryan,
As I understand it, you have some inquiries related to SD SDI with SDI II IP. Just would like to check with you which Quartus and device that you are using? Also, just wonder if you are using the SDI II IP as TX or RX?
