(vlog-13006) Could not find the package (avalon_mm_pkg). See line 32, 33 in Transcript Code generated by modelsim. Where can i find this avalon_mm_pkg.sv code, and where should i put it? Thanks, PVanL
i built a PHY for the cyclone10GX. I now want to connect the LL 10G MAC to it, and as test now trying to run the alt_em_10g32_EXAMPLE_DESIGN generated by QUARTUS version 18.0.0 build 219 04/24/2018 SJ Pro Edition with Cyclone10GX libraries. Modelsim version starter edition 10.6C, revision 2017.07.
I managed to get the msim_setup.tcl script running, until i face the following issue : when it compiles avalon_driver.sv, in line 66 it wants to import avalon_mm_pkg, but this file does not exist.
Modelsim reports (after compiling a lot of cyclone stuff)
# Top level modules:
# End time: 18:02:38 on Jun 25,2019, Elapsed time: 0:00:08
# Errors: 0, Warnings: 584
# Model Technology ModelSim - Intel FPGA Edition vlog 10.6c Compiler 2017.07 Jul 26 2017
# Start time: 18:02:38 on Jun 25,2019
# vlog -reportprogress 300 C:/intelfpga_pro/18.0/quartus/eda/sim_lib/cyclone10gx_hip_atoms.v -work cyclone10gx_hip_ver
# -- Compiling module cyclone10gx_hssi_gen3_x8_pcie_hip
# -- Compiling module twentynm_hssi_gen3_x8_pcie_hip
# cyclone10gx_hssi_gen3_x8_pcie_hip
# twentynm_hssi_gen3_x8_pcie_hip
# End time: 18:02:38 on Jun 25,2019, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0
# [exec] com
# vlog -reportprogress 300 -sv ../../../rtl/phy/altera_eth_10gbaser_phyaltera_xcvr_native_a10_180/sim/altera_xcvr_native_a10_functions_h.sv -work altera_common_sv_packages
# -- Compiling package altera_xcvr_native_a10_functions_h
# --none--
# vlog -reportprogress 300 -sv "+incdir+../models" ../models/tb_top.sv
# -- Compiling package eth_register_map_params_pkg
# -- Compiling package avalon_if_params_pkt
# -- Compiling module avalon_bfm_wrapper
# -- Importing package avalon_if_params_pkt
# ** Error: ** while parsing file included at ../models/tb_top.sv(19)
# ** at ../models/avalon_driver.sv(66): (vlog-13006) Could not find the package (avalon_mm_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
# End time: 18:02:39 on Jun 25,2019, Elapsed time: 0:00:01
# Errors: 1, Warnings: 0
# ** Error: C:/intelFPGA_pro/18.0/modelsim_ase/win32aloem/vlog failed.
# Error in macro ./mentor.do line 25
# C:/intelFPGA_pro/18.0/modelsim_ase/win32aloem/vlog failed.
# while executing
# "vlog -sv {+incdir+../models} "../models/tb_top.sv" "
# ("eval" body line 1)
# invoked from within
# "eval $file"
# ("foreach" body line 2)
# "foreach file $design_files {
# eval $file
# ("eval" body line 13)
# "com"I then found in Quartus II software 11.1 release notes (2011!) the following:
Simulating an Avalon MM master or slave BFM with msim_setup.tcl in ModelSim leads to errors
Description
If you attempt to simulate an Altera Avalon Memory-Mapped (MM) Master bus functional model (BFM), or an Altera Avalon MM Slave BFM using the generated Model-
Sim script msim_setup.tcl, ModelSim may issue error messages similar to the following:
Error: test_module.sv(2): Could not find the package (avalon_mm_pkg).
Error: (vsim-8386) ./test_module.sv(75): An enum variable may only be assigned the same enum typed variable or one of its values.
Workaround
Perform one to the following steps:
• At a command prompt, run “ip-make-simscript --spd=<generated_spd_file>
--compile-to-work” to regenerate the ModelSim simulation script that compiles
all component into a single work library, or
• Manually modify the msim_setup.tcl script to compile all files into a single work
library.
i tried to follow this, but don't have a clue what i am doing....
“ip-make-simscript --spd=avalon_mm_pkg --compile-to-work”
# invalid command name "“ip-make-simscript"
do ip-make-simscript --spd=avalon_mm_pkg --compile-to-work
# Cannot open macro file: ip-make-simscript
- PVanL
How do I edit my own question?
I found an avalon_mm_pkg.sv.
I added avalon_mm_pkg.sv to EXAMPLE/simulation/ed_sim/models, where the other verilog code is located. (avalon_various.sv, eth_various.sv, default_test_params_pkg.sv and tb_top.sv)
I added in tb_top.sv line 22 `include "avalon_mm_pkg.sv".
I added in avalon_driver.sv line 20 `include "avalon_mm_pkg.sv".
See code snippet 1
Msim Transcript reports: see sode snippet 2.
Line 8: In line 38 of avalon_mm_pkg.sv, a packet is called but not found. [encrypted]. There is no vopt-7 error.
Line 10: As a result of course, the avalon_driver cannot import the avalon_mm_pkg parameters @ Line 67 import avalon_mm_pkg::*;
Please advice
In tb_top.sv 18 `include "eth_register_map_params_pkg.sv" 19 `include "avalon_driver.sv" 20 `include "avalon_st_eth_packet_monitor.sv" 21 `include "default_test_params_pkg.sv" 22 `include "avalon_mm_pkg.sv" //NEW added by pieter In avalon_driver.sv 17`include "avalon_if_params_pkg.sv" 18 `include "avalon_bfm_wrapper.sv" 19 `include "eth_mac_frame.sv" 20 `include "avalon_mm_pkg.sv" //NEW added by pieter# vlog -reportprogress 300 -sv "+incdir+../models" ../models/tb_top.sv # -- Compiling package eth_register_map_params_pkg # -- Compiling package avalon_if_params_pkt # -- Compiling module avalon_bfm_wrapper # -- Importing package avalon_if_params_pkt # ** Error: ** while parsing file included at ../models/tb_top.sv(19) # ** while parsing file included at ../models/avalon_driver.sv(20) # ** at ../models/avalon_mm_pkg.sv(38): (vlog-13006) Could not find the package (<protected>). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line. # ** Error: ** while parsing file included at ../models/tb_top.sv(19) # ** at ../models/avalon_driver.sv(67): (vlog-13006) Could not find the package (avalon_mm_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line. # End time: 12:42:59 on Jun 26,2019, Elapsed time: 0:00:01 # Errors: 4, Warnings: 0 # ** Error: C:/intelFPGA_pro/18.0/modelsim_ase/win32aloem/vlog failed. # Error in macro ./mentor.do line 25 # C:/intelFPGA_pro/18.0/modelsim_ase/win32aloem/vlog failed. # while executing # "vlog -sv {+incdir+../models} "../models/tb_top.sv" " # ("eval" body line 1) # invoked from within # "eval $file" # ("foreach" body line 2) # invoked from within # "foreach file $design_files { # eval $file # }" # ("eval" body line 13) # invoked from within # "com"- Shubhall
I was facing the similar problem and here is the solution -
1. Add avalon_mm_pkg.sv and verbosity_pkg.sv in the model folder where tb_top.sv is located.
2. Compile the verbosity_pkg.sv using the command "vlog -reportprogress 300 -sv "+incdir+../../models" ../../models/verbosity_pkg.sv" .
3. Now compile avalon_mm_pkg.sv using "vlog -reportprogress 300 -sv "+incdir+../../models" ../../models/avalon_mm_pkg.sv" .
4. Compile the tb_top.sv file " vlog -reportprogress 300 -sv "+incdir+../../models" ../../models/tb_top.sv".
5. Now try running again using ld_debug.
Foe me it solved using these steps. I was using Questa (Quartus prime 22.2).
Thank you
- RichardT_altera
Hi Pieter,
Apologize for idle for a while, has the issue solved? Do you need my help with your inquiry?
