JLee25
Contributor
6 years agoVIP Suit Switch II Ready Signal
Hello, I am working on a simple project that with CVI/ PTG -> Switch -> CVO -> HDMI at 1080p. Sometimes the CVO is not outputting any signal from PTG. From Signal Tap, I noticed for CVO or S...
CheepinC_altera
6 years agoHi,
Thanks for your update. Would you mind to further elaborate on what is the new configuration that you have loaded to the Switch? Please share with us the detailed steps ie the register and values that you are writing to configure the Switch to see if we can spot any anomaly? Also, mind share more on the 2 different ways that you mentioned tested?
Thank you.
