JLee25
Contributor
6 years agoVIP Suit Switch II Ready Signal
Hello, I am working on a simple project that with CVI/ PTG -> Switch -> CVO -> HDMI at 1080p. Sometimes the CVO is not outputting any signal from PTG. From Signal Tap, I noticed for CVO or S...
KKnig4
6 years agoHi Johnson,
When you say "Sometimes the CVO is not outputting..." - does it ever output anything from the PTG?
Is your software setting the switch up correctly to select between the CVI/PTG? The switch's control register expects a one-hot value to select the required input.
Are you getting any output from the CVO btw?
K
