14 years ago
VIP and NIOS2 don't work together
Hi group,
I am building a small monitor system using D5M and DE2-115.
My current working code is like:
D5M camera -> some processing -> Clocked_Video_Input -> alpha_mixer -> Clocked_Video_Output -> VGA port on the board. Images from camera can be displayed on an external monitor correctly.
Then I tried pattern_generator -> alpha_mixer (controlled by a NIOS2) -> Clocked_Video_Output -> VGA port, and it also works.
Now I am trying to combine these two, which is just to add the NIOS2 to control the alpha_mixer in the first design. And now I cannot see the output anymore. The NIOS2 core did nothing except initiating the alpha_mixer core. I don't know what's wrong with it.
One thing I noticed is that the overflow signal from the clocked_video_input core went high.
Anyone has some suggestions? thanks.
    try to always use the test pattern generator, i think the mixer should have one
    Thanks for the reply, mrbietola.
    I did try test_pattern_generator. I added 3 channels to the mixer, two were from test_pattern_generator, one were from my VGA data channel. The only thing the CPU did was to switch between these channels according to key press. I can switch between test_pattern_generator channels and display them correctly, but the image of my VGA data channel doesn't display right (I mean a black screen was shown) if I switch to this channel. If I remove the mixer and the CPU, leaving only my data channel in the path, then the image is good again.....
    I'm having a similar problem with a Nios II interfering with a VGA driver that I wrote. The systems are totally independent of one another except for being contained in the same entity. I don't get it. Any thoughts?
