14 years agoVideo Scaler in VIP
Hi, I try to implement a hardware design which scales an incoming video signal. With the new resolution the signal should output on a display. My Plan is to do this with the help of the “Video and...
14 years agoI would suggest you set the value of "Fifo level at which to start output" to almost the complete size of the FIFO - like the FIFO size minus 1 to 5 or something like that. This should reduce the risk of the CVO being starved of data at a critical time.
