14 years agoVideo Scaler in VIP
Hi, I try to implement a hardware design which scales an incoming video signal. With the new resolution the signal should output on a display. My Plan is to do this with the help of the “Video and...
14 years agoI noticed that about every third or fourth time I programmed the FPGA the systems works. It seems to be a issue with the sync.
In the settings of the CVO there is a input field "Fifo level at which to start output" Can you advise a value for this field? (The Resolution of the screen is 1366x768)
