14 years agoVideo Scaler in VIP
Hi, I try to implement a hardware design which scales an incoming video signal. With the new resolution the signal should output on a display. My Plan is to do this with the help of the “Video and...
14 years agoYou could double this to two lines to be safe (and make sure the CVO is set to only start outputting when the FIFO is nearly full), but this shouldn't be necessary. You could also try changing to the Scaler II (I think you are suing the old scaler at the moment).
