16 years agoVHDL-Code with Avalon Bus Interface-/ and VHDL-Video-System-Interface-Ports
Hello I provided the following ENTITY. Can I actually provide a IP, which some haven connectivity with the Avalon bus, as well as haven as down descriptive for the VHDL_Detector, which is not c...
16 years agoThanks Kevin, this help me well.
But now I have another problem: Here the complete vhdl-code: LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; USE ieee.numeric_std.all; ENTITY ime_avalon_xy_detector IS PORT ( -- Avalon Conduit to VHDL_Detector Clock Interface coe_iVGA_CLK : in std_logic; coe_iRST_N : in std_logic; -- Avalon Conduit to VHDL_Detector IN-Ports coe_iVGA_R : in std_logic_vector(9 downto 0); coe_iVGA_VS : in std_logic; -- Avalon Clock Interface csi_clk : in std_logic; csi_rst_n : in std_logic; -- Avalon-MM Interface / Slave Port avs_address : in std_logic; avs_write : in std_logic; avs_writedata : in std_logic_vector(31 downto 0); avs_read : in std_logic; avs_readdata : out std_logic_vector(31 downto 0) ); END ENTITY ime_avalon_xy_detector; -- ARCHITECTURE rtl OF ime_avalon_xy_detector IS SIGNAL coordinate_wr : std_logic_vector(31 downto 0); SIGNAL coordinate_rd : std_logic_vector(31 downto 0); SIGNAL x : std_logic_vector(15 downto 0); SIGNAL y : std_logic_vector(15 downto 0); SIGNAL dat_0 : integer range 0 to 1000000 := 100000; -- 0x186A0 SIGNAL dat_1 : integer range 0 to 1000000 := 111111; -- 0x1B207 BEGIN write_proc: process(csi_clk, csi_rst_n) begin if csi_rst_n = '0' then coordinate_wr <= (others => '0'); x <= (others => '0'); y <= (others => '0'); elsif rising_edge(csi_clk) then if avs_write = '1' then coordinate_wr <= avs_writedata; end if; end if; end process write_proc; read_proc: process(csi_clk, csi_rst_n) begin if csi_rst_n = '0' then coordinate_rd <= (others => '0'); avs_readdata <= (others => '0'); x <= (others => '0'); y <= (others => '0'); elsif rising_edge(csi_clk) then coordinate_rd <= coordinate_wr; if avs_address = '0'then coordinate_rd <= std_logic_vector(to_unsigned(dat_1, 32)); elsif avs_address = '1' then coordinate_rd <= std_logic_vector(to_unsigned(dat_0, 32)); end if; if avs_read = '1' then avs_readdata <= coordinate_rd; end if; end if; end process read_proc; END ARCHITECTURE rtl; in this case the NiosII can not load the prgram in ram. Here the messagge: Verifying 00080000 ( 0%) Verify failed between address 0x80000 and 0x8D0DB Leaving target processor paused but when I change the part with the avs_address as below: if avs_address = '0'then coordinate_rd <= std_logic_vector(to_unsigned(dat_0, 32)); elsif avs_address = '1' then coordinate_rd <= std_logic_vector(to_unsigned(dat_1, 32)); end if; the NiosII will work good. Thats very strange..... Have you any idea???????
