15 years agoVCO parameters for 1920x1080i50hz video
I'm trying to use the Clocked Video Output IP with the SOPC builder I need to output a 1920x1080i50hz video with separate sync signals. To create the separate sync signals the wizard needs the fol...
14 years agoHi Jimmy,
did you get a solution for your Problem? I have the same Problem, I need seperate wires and SDI-Signals 1920x1080. Can you help me? Anja
