Using Video IP with time limited sof II
Hi
Thanks for update. In summary :
• Test passed : using old design with temp license that generate RBF
• Test also passed : using old design with evaluation license that generate time limited sof
• Test failed : using new design with evaluation license that generate time limited sof
in the test that you perform, we know that the original project can produce RBF and SOF file successfully. Yes, the literature does not indicate the license make the time limited SOF work. But here we can know that the design update is the cause of the failure not the licensing issue.
For your question “Do I need to retrofit the new logic to this baseline?” the suggestion is that you need to slowly isolate and debug which part of your new added design is causing the failure. The new design might uses some IP solution that required extra license that’s not supported in evaluation license end up causing failure.
