BMart12
5 years agoUsing Video IP with time limited sof II
community.intel.com/t5/FPGA-Intellectual-Property/Using-Video-IP-with-time-limited-sof/m-p/1285319#M24002
I was instructed by AabdRhman_A_Int el to resubmit my inquiry regarding the tim...
AR_A_Intel
5 years agoThanks for update. Kindly provide the .rbf and .sof log if error happen.
- BMart125 years ago
Hi AR_A,
I generated the time limited SOF using the project that originally produced the RBF. Booting the system with the SOF launches the graphic terminal with the LXDE display. I ran a test and confirmed that the second LCD also works. This particular project was implemented several months ago. We have progressed and produced new versions with additional modules and custom IP blocks. Do I need to retrofit the new logic to this baseline? The literature does not indicate I needed a previously working VIP license to make the time limited SOF work.
Ben
