Using Video IP with time limited sof II
Hi Ben Martinez
Welcome to INTEL forum. I’ll be taking this case and help you on the diagnosis of Video IP with time limited sof. But first, may I know, did you modify the design or just recompile the same design with different license type (temp license vs evaluation mode license)
Hi AR_A,
Thank you for your quick response. I did not use the identical Quartus project for both. The design evolved from when I generated the RBF. However, I can generate the time limited SOF from the project that produced the working RBF. Please let me know if you need me to do that.
I am guessing the time limited SOF is generated by the evaluation mode license which is what I get when building the project with my standard license. So, does changing the design affect the capability of the evaluation mode time limited SOF?
Ben Martinez
