8 years agoUsing TSE with PCIe in a Linux enviroment
Hello, I hope someone can help me. I want to use the altera TSE as an ethernet connection in a x86-PC-design. I'm using PCIe to connect the FPGA to the CPU and the OS is Linux. The system is...
8 years agoHi Chris,
To configure the TSE register is via the Avalon MM interface. If you can access the PIO, then you should be able to access the TSE register as well. It is just difference addressing. Regards Terence (This message was posted on behalf of Intel Corporation)
