8 years agoUsing TSE with PCIe in a Linux enviroment
Hello, I hope someone can help me. I want to use the altera TSE as an ethernet connection in a x86-PC-design. I'm using PCIe to connect the FPGA to the CPU and the OS is Linux. The system is...
8 years agoHi Christh,
As per my understanding, the TSE IP is not directly connected to the PCIE. There should have some logic+ memory to process and store the Ethernet Packet, and the root port can issue a memory read or write command via PICE to access memory for the Ethernet data. For example: X86 -> PCIE -> Logic + Memory -> TSE Best Regards, Terence (This message was posted on behalf of Intel Corporation)
