12 years agoUsing Stratix V Transceiver native PHY core in the place of Arriai V PHY core
Hi All, Is it possible to directly replace the Transceiver native PHY core of Arria V GZ with Stratix V Transceiver native PHY core? If so how can it be implemented. Though its been stated Arria ...
12 years ago --- Quote Start --- You do not need an over-ride, just instantiate the PHY in direct mode (no PCS) or use the 10G PCS. They both work fine. Cheers, Dave --- Quote End --- Hi Dave, Yes that would help but I intend to retain the rest of the design to be the same and do not want major changes. When I consulted with Altera they suggested the above quoted solution if I intend to go with the standard PCS. I am waiting for their response meanwhile wanted to know if some one already tried it. Thanks Gowtham
