17 years agoUsing SODIMM DDR2 module on Cyclone 3
Hi All, Hope someone can help. I'm just trying to establish the feasibility of using a SODIMM memory DDR2 memory module (e.g Micron MT16HTS25664H) with a Cyclone III FPGA (EP3C40F484C6 o...
17 years agoIt may be worthwile to look whether you need the full speed, if not you could implement the memory interface using a PLL to clock the SDRAM read data. This will allow you to optimize the pin per bank usage.
