15 years agoUsing multiple LPMs of same type but different characteristics
Hi all,
I was trying to find a way to use the sam LPM Megafunction but with different settings. For example, the lpm_add_sub function, I would like to have both an adder and subtractor but can't figure it out. - Here's an example COMPONENT lpm_sub GENERIC ( lpm_direction : STRING := "ADD"; lpm_hint : STRING := "ONE_INPUT_IS_CONSTANT=NO,CIN_USED=NO"; lpm_representation : STRING := "SIGNED"; lpm_type : STRING := "LPM_ADD_SUB"; lpm_width : NATURAL := 32 ); PORT ( dataa : IN STD_LOGIC_VECTOR(31 DOWNTO 0); datab : IN STD_LOGIC_VECTOR(31 DOWNTO 0); result : OUT STD_LOGIC_VECTOR(31 DOWNTO 0) ); END COMPONENT; - and then instantiate it with: lpm_sub_component : lpm_sub PORT MAP ( a, c, result_sub ); - I get Error: Node instance "lpm_sub_component" instantiates undefined entity "lpm_sub" So it appears the component name has to be that of the lpm function. What is the use of the LPM_TYPE characteristic then? Thanks4 Replies
At some point the compiler will search for the entity "lpm_sub", which you probably haven't created as you want to invoke an existing LPM function. Hence the error.
LPM_TYPE is to be seen as a constant rather than a parameter. LPM functions go back a long time, at some point it was an industry standard. You could do it like thislibrary lpm ; use lpm.lpm_components.all ; - - - lpm_sub_component1 : lpm_add_sub generic map ( lpm_direction : STRING := "ADD"; . . . ) port map ( . . . ) ; lpm_sub_component2 : lpm_add_sub generic map ( lpm_direction : STRING := "SUB"; . . . ) port map ( . . . ) ; - Altera_Forum
That works, thanks!
even simpler, use behavioural VHDL:
c <= a + b; f <= d - e; etc. - Altera_Forum
--- Quote Start --- even simpler, use behavioural VHDL: c <= a + b; f <= d - e; etc. --- Quote End --- yes it is a lot less typing and I do it that way almost always, but that wasn't the question ... necsup was contemplating LPM-functionality in general
