CosmoKramer
1 year agousing emif ip amm interface
Hello, We are using quartus 23.4 and seeing discrepancy in the polarity of ctrl_amm signal on the emif ip between documentation and the example design. As per simulation of the example design - r...
AdzimZM_Altera
1 year agoHello,
The amm_ready signal from the EMIF IP module is an active low signal.
The controller is busy when this signal is low.
The description may a bit confusing.
I will try to raise this concern to improve in the UG.
Adzim
