CosmoKramer
1 year agousing emif ip amm interface
Hello, We are using quartus 23.4 and seeing discrepancy in the polarity of ctrl_amm signal on the emif ip between documentation and the example design. As per simulation of the example design - r...
matferronato
1 year agoI've also raised this issue in one of the replies in this topic. I believe this is an oversight on the documentation side. Maybe it should be flagged to be patched in the next revision.
