CosmoKramer
1 year agousing emif ip amm interface
Hello, We are using quartus 23.4 and seeing discrepancy in the polarity of ctrl_amm signal on the emif ip between documentation and the example design. As per simulation of the example design - r...
AdzimZM_Altera
1 year agoHello,
Which ctrl_amm signal that you mean? Can you provide the screenshot as well? Thanks.
Maybe you can check in the example design top level file to see if the signal has been negated.
Adzim
