Fletch
2 years agoUniphy DDR3 Data Corruption
I'm hoping someone in this forum has some insight on data corruption I am seeing when accessing a discrete DDR3 using Uniphy IP. I first noticed data errors when using it as a video frame buffer. No...
- 2 years ago
Hi Adzim,
I was able to correct this. My refresh cycle time was too short.
Brandon
Andrey4
2 years agoHello! I'm also using two chips "MT41K256M16DA-107" as a video frame buffer. Avalon-MM interface is 128-bit data and 26-bit address. I fill the frame with some test data. I looked in Signal Tap, and it shows that data from some memory address cells is not the same as I wrote before (see attached file - each address should contain 0xf800f800f800f80007e007e007e007e0, but some of them suddenly contain something else). And I have some artifacts on display because of this
