FHint
4 years agoUnable to read data from flash via Generic Serial Flash Interface (only zeros)
in my current Arria 10 GX design I have one small Micron flash for the FPGA binary (MT25QU256ABA1EW9, 32MByte) and two larger Micron flash devices (MT25QU01GBBB1EW9, 128 MByte each) for rand...
- 3 years ago
thank you for the reply. It isn't necessary to check the project anymore, because it now works.
The problem was solved by switching from version 19.1 to 21.1 of the Quartus Prime Standard software.
Florian
Farabi_Altera
4 years agoHello,
To speed up debugging work, do you have a test case where we can replicate the issue at our end?
regards,
Farabi
FHint
4 years agoHello,
what exactly do you need to replicate the issue?
Do you need a project that includes the component that interacts with the GSFI or is the source code of the component sufficient?
Florian
