Unable to read data from flash via Generic Serial Flash Interface (only zeros)
- 3 years ago
thank you for the reply. It isn't necessary to check the project anymore, because it now works.
The problem was solved by switching from version 19.1 to 21.1 of the Quartus Prime Standard software.
Florian
To speed up debugging work, do you have a test case where we can replicate the issue at our end?
regards,
Farabi
- FHint4 years ago
what exactly do you need to replicate the issue?
Do you need a project that includes the component that interacts with the GSFI or is the source code of the component sufficient?
Florian - FHint4 years ago
Hello Farabi,
I'd like to bump the thread up again, because I am pretty stuck with this issue and it doesn't seem to be an hardware bug, because I can clearly see the correct SPI response in SignalTap (see my original post).
What do you need to replicate the issue?
Florian
