Unable to generate AXI Streaming Intel FPGA IP for PCIe Example design for F-Tile FPGA Agilex 7 R24C
- 1 year ago
In Q24.1 the design example generation is only for P-Tile and R-Tile.
You can simply instantiate one IP in your project or copy that IP from your previous project.
Rong
From my side, I'm able to generate an example design in Q24.1 Pro.
Please check the Quartus files you downloaded have correct SHA1 checksum.
You can create an empty project based on AGFB014R24C2E2V. In "IP Catalog", find "F-Tile Avalon Streaming Intel FPGA IP for PCI Express" and create an IP. With all default settings, you can click "Generate Example Design" then it should generate one.
Rong
Hi RongYuan,
I am still unable to generate the example design. I created a new project with default settings and still unable to generate.
"Please check the Quartus files you downloaded have correct SHA1 checksum." How do I check this? Could you share the steps.
Thank you,
Best Regards.
