9 years agoUnable to acitvate 88e1111 on DEII-115
I am unable to actvate the 88e1111 on my DE2-115. (Nios is running, config with cpu, on chip mem, 2xscattergather DMA, and 1 TSE, as in the docmentation of various tutorials, RGMII is set via jumper and selected in QSYS) I narrowed down my problem to a very simple program (based on the examples and the Altera Triple-Speed ethernet docs). First observation is that even the link LED on my switch does not come up. (cable and switch were tested with a PC). The speed leds on the DE2-115 indication the PHY baud rate and other leds near the chip stay dark. The data sheet of the 88e1111 cannot be found, this not helping. questions: 1) What are the minimum requirements to get the link up ? Is this done by the PHY by itself (i assume) ? Does it suffice to initialize the MAC adresses, the MDIO space 0, and the right value in register 16 of the PHY. 2) I can read and write the scratch register and read the TSE version. But if i use the following code to reset the PHY, nios hangs:alt_printf(" Software reset of PHY chip and wait ... \n");
*(tse + 0x80) = *(tse + 0x80) | 0x8000;
while ( *(tse + 0x80) & 0x8000 );
alt_printf(" Software reset of PHY chip ok ! \n");
I included a print of my qsys configuration, a copy of the instantiation and my C program as a .doc. Many thanks in advance. Johi.2 Replies
Hi Johi,
the marwell datasheet can be found on www.eeworld.com.cn Sorry I haven't read your code yet, but the tse_tutorial.c and tse_tutorial.v from using_triple_speed_ethernet work fine on DE115 board. These codes were written for 1000 speed. I don't know for other speed. On DE115 the hardware is only for RGMII ( I asked terasic and the schematic shows it). If you want to only use the 1000 speed the marwell ( and some other chips ) are set in this mode when reset. The DDR is necessary. The demo code tse_tutorial is a goog start. I hope it will be helpfull. Regards. - Altera_Forum
Hi garfieldminou,
Thanks for the answer. I was unable to retrieve the datasheet from the site you mentioned. The site is in a language i do not understand, it seems chinese or japanese or some other language i do not speak. In the mean time i have got the DE115 tse example working. The pin assignment of te Terrasic application builder and that of the DE115 of tse the example are different. Once i found this i got the example working. Morover, sometimes the leds on the 88e1111 are activated just by loading the nios code. Sometimes they need a reset from the .c code to light up. In an other example they only start working when you actually send data. Best Regards, Johi.
