11 years ago
UART (RS232) IP without NIOS core
I've been trying to test the behaviour of the UART IP using a test bench but I'm failing to get any output from txd. I've setup the following test bench but am not getting any results, can someone please tell me where I am going wrong? "readyfordata" never asserts and I'm not sure why. The address input relates to the last image (https://www.altera.com/en_us/pdfs/literature/ug/ug_embedded_ip.pdf). Please help!
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY uart_vhd_tst IS
END uart_vhd_tst;
ARCHITECTURE uart_arch OF uart_vhd_tst IS
-- constants
-- signals
SIGNAL clk : STD_LOGIC:='0';
SIGNAL ext_con_rxd : STD_LOGIC := '1';
SIGNAL ext_con_txd : STD_LOGIC := '1';
SIGNAL reset_n : STD_LOGIC := '0';
SIGNAL uart_address : STD_LOGIC_VECTOR(2 DOWNTO 0):="001";
SIGNAL uart_begintransfer : STD_LOGIC := '0';
SIGNAL uart_chipselect : STD_LOGIC := '1';
SIGNAL uart_dataavailable : STD_LOGIC := '0';
SIGNAL uart_read_n : STD_LOGIC := '1';
SIGNAL uart_readdata : STD_LOGIC_VECTOR(15 DOWNTO 0):=(others=>'0');
SIGNAL uart_readyfordata : STD_LOGIC:='0';
SIGNAL uart_write_n : STD_LOGIC := '1';
SIGNAL uart_writedata : STD_LOGIC_VECTOR(15 DOWNTO 0):=(others=>'0');
COMPONENT uart
    PORT (
    clk : IN STD_LOGIC;
    ext_con_rxd : IN STD_LOGIC;
    ext_con_txd : OUT STD_LOGIC;
    reset_n : IN STD_LOGIC;
    uart_address : IN STD_LOGIC_VECTOR(2 DOWNTO 0);
    uart_begintransfer : IN STD_LOGIC;
    uart_chipselect : IN STD_LOGIC;
    uart_dataavailable : OUT STD_LOGIC;
    uart_read_n : IN STD_LOGIC;
    uart_readdata : OUT STD_LOGIC_VECTOR(15 DOWNTO 0);
    uart_readyfordata : OUT STD_LOGIC;
    uart_write_n : IN STD_LOGIC;
    uart_writedata : IN STD_LOGIC_VECTOR(15 DOWNTO 0)
END COMPONENT;
BEGIN
    clk <= not clk after 20 ns;
    i1 : uart
    PORT MAP (
-- list connections between master ports and signals
    clk => clk,
    ext_con_rxd => ext_con_rxd,
    ext_con_txd => ext_con_txd,
    reset_n => reset_n,
    uart_address => uart_address,
    uart_begintransfer => uart_begintransfer,
    uart_chipselect => uart_chipselect,
    uart_dataavailable => uart_dataavailable,
    uart_read_n => uart_read_n,
    uart_readdata => uart_readdata,
    uart_readyfordata => uart_readyfordata,
    uart_write_n => uart_write_n,
    uart_writedata => uart_writedata
init : PROCESS
-- variable declarations
BEGIN
     reset_n <= '1' after 100 ns;
WAIT;
END PROCESS init;
always : PROCESS
-- optional sensitivity list
BEGIN
        -- code executes for every event on sensitivity list
        uart_writedata <= x"00F0" after 100 ns;
        uart_write_n <= '0' after 140 ns;
        uart_begintransfer <= '1' after 140 ns;
WAIT;
END PROCESS always;
END uart_arch;
http://www.alteraforum.com/forum/attachment.php?attachmentid=10444&stc=1
http://www.alteraforum.com/forum/attachment.php?attachmentid=10445&stc=1
