MamaSaru
2 years agoTX sync header error insertion in Arria 10 GX
Hi, I have a problem regarding Tx error insertion function on Arria 10 GX 10GBASE-R with FEC. I have built two duplex 10GBASE-R with FEC PHYs on my board, connecting Tx to Rx through DAC cable. Pa...
ZiYing_Intel
2 years agoHi,
You may check the sync header error status under the PCS> encode>sync_out in the simulation file.
The error flag means the sync header error. The CRC is inserted in the last 4 bytes of the frame (user data) by MAC block. Then, user data is sent to TX PCS, where 64B/66B operation is done. After this, the sync header error is added in the PCS block.
zying
MamaSaru
2 years agoDid you send any files?
