12 years agoTwo sustom avl mm master to ddr3 uniphy controller
First I have created a custom avl mm master to DDR3 Uniphy controller slave, connected it to DDR3 controller along with pll in QSYS and using that I have perform Write read operations in the DDR3 mem...
12 years ago --- Quote Start --- I don't use that controller so I can't answer for sure but I think that you can just start doing an operation right away. If the controller is calibrating, it will just pause your component by holding waitrequest until it is ready to process it. --- Quote End --- Thanks Daixiwen, I will just check with it whether it works like you said or I will prefer the the initial delay method to wait for initialization done and start writing.
