14 years agoTSE without MDIO
Greetings,
I have a board with several Vitesse phys, each one of then with 4 ports. All the phys are connected to my Arria II GX through a SMI bus. So far I've been able to configure the phys, on NIOS (this will be later done by hardware only), through a custom MDIO module connected to some PIOs. The phys are getting link with the link partner (my PC) and the registers says that the MAC side auto-negotiation is complete and link is up. All fine. But when I try to exercise it sending some packets with bittwist from my PC, I see no signal changes on TSE RX pins. So, I suppose TSE is not properly initialized, but how can it be done since it does not have MDIO to get information from the phys registers? Is there a way to manually configure\initialize the MAC without MDIO at TSE IP core? Thank you !!1 Reply
--- Quote Start --- Is there a way to manually configure\initialize the MAC without MDIO at TSE IP core? --- Quote End --- MAC Configuration Register Space, chapter 5 of TSE User Guide. :oops: Thank you.
