14 years agoTSE with SGMII in Cyclone IV GX - ALTGX_RECONFIG problem
Ok, I'm confused with this. I built a Qsys system with CPU, TSE with SGMII and some Flash/SSRAM on a Tristate bus. This all seems fine, and I can make it compile if I remove the TSE or reconfigure ...
14 years agoI just did the same thing except the Mega Wizard generated the correct
matching reconfig block. I'm guessing you need to do it in the same directory and generate the sgmii module first. The the wizard seems to pick up on what is needed to match the sgmii module. None of the design examples show much details on implementing sgmii, especially the register 'h14 write.
