14 years agoTSE UDP Streaming Problem
Hi everyone, I know similar problems were discussed in this forum several times but no thread helped me on my problem. My design is targeting the DE2-115 and is based on the UDP Offload ex...
14 years agoOh yes I didn't think about that. The channel adapter is added automatically because the multiplexer creates a channel signal (to indicate which source the packet came form) but the TSE's sink doesn't support channels. Now from the documentation:
--- Quote Start --- You can also use this adapter to connect a source with a wider channel to a sink with a narrower channel. If the source provides data for a channel that the sink cannot receive, the data is not transferred. --- Quote End --- This is rather unintuitive. The adapter isn't even configurable so you can't say what channels you want through, it will just discard the extra channels. IT looks like the only solution is to write your own adapter, or modify the existing one (but in that case be very careful that SOPC Builder/QSys doesn't overwrite your code the next time you generate!).
