14 years agoTSE UDP Streaming Problem
Hi everyone, I know similar problems were discussed in this forum several times but no thread helped me on my problem. My design is targeting the DE2-115 and is based on the UDP Offload ex...
14 years agoSOLVED!
As you could see on SignalTap the stream was valid, BUT: The automatically inserted ST Channel Adapter surely only forwards one channel. With using the multiplexer it creates a stream with two channels and the channel adapter deletes the "valid"-signal of the second channel. So all of the data was coming to the TSE but with a constant low "valid"-signal. By manually altering the channel adapter verilog file it works. Every packet is completely transmitted by the TSE. But I am still wondering why the adapter is automatically inserted after a multiplexer... by discarding one channel there would be no need for the multiplexer...
