14 years agoTSE UDP Streaming Problem
Hi everyone, I know similar problems were discussed in this forum several times but no thread helped me on my problem. My design is targeting the DE2-115 and is based on the UDP Offload ex...
14 years agoI checked all connections to the TSE, see attached a screen capture of SignalTap. On input 0 is the SGDMA with the data from InterNiche and on input 1 is the UDP hardware.
As far as I can see everything of the protocol stuff is working correctly. Pinging the board does always work. Also interesting: In my design the UDP hardware theoretically generates too much data for a 10/100 MBit connection but the TX buffer never gets full. As you can see in the SignalTap the Ready signal for the multiplexer output is always high.
