14 years agoTSE UDP Streaming Problem
Hi everyone, I know similar problems were discussed in this forum several times but no thread helped me on my problem. My design is targeting the DE2-115 and is based on the UDP Offload ex...
14 years agoDid you check with SignalTap all the signals between the multiplexer and the TSE, when you send a packet? IIRC there is no reason why the TSE wouldn't transmit a packet that is placed on its Avalon stream sink, so as long as this protocol is followed correctly (start of packet, data, end of packet, and respect of the ready/valid signals).
Did you try to ping the board after trying to send a packet through the hardware UDP cores? Just to be sure the TSE isn't stuck in a strange state.
