14 years agotse transmission get hanged in TCP protocal
Hello,everyone! I want to transfer data between my laptop(the OS is windows XP) and my Stratix III 3sl150 board through ethernet wire. I'm using the hardware and software design found here...
14 years ago --- Quote Start --- No, because IP packet size is way much smaller, than 225k.The FIFO is inside TSE MAC. Why don't You use UDP? That's a common protocol for image/video streaming. --- Quote End --- Because I think when using UDP, it's not guaranteed that every small packet will be received, and also the data received may not be correct.
