14 years agotse transmission get hanged in TCP protocal
Hello,everyone! I want to transfer data between my laptop(the OS is windows XP) and my Stratix III 3sl150 board through ethernet wire. I'm using the hardware and software design found here...
14 years ago --- Quote Start --- The best would be -Os, but still, should be fine... Anyway, I see that You're doing TCP connections, when I remembered, that I've tested UDP streams, when reached ~10Mbps. I'd say that it's just too slow to handle such speeds. What's the Nios CPU frequency and how many MIPS does it show? --- Quote End --- The Nios CPU frequency is 62.5Mhz; for "many MIPS does it show", I don't know where to check it. I intend to transmit bmp pictures(about 225kb for each picture), I think it will be cut into smaller packets when transmitting through the net wire, so I choose TCP to guarantee the integrity of the data. By the way, you mentioned "Probably FIFO buffers are filled up...", in my case, do I need a FIFO buffer larger than 225k(currently, my buffer size is 2048 bytes)?
