14 years agotse transmission get hanged in TCP protocal
Hello,everyone! I want to transfer data between my laptop(the OS is windows XP) and my Stratix III 3sl150 board through ethernet wire. I'm using the hardware and software design found here...
14 years agoThe best would be -Os, but still, should be fine... Anyway, I see that You're doing TCP connections, when I remembered, that I've tested UDP streams, when reached ~10Mbps. I'd say that it's just too slow to handle such speeds. What's the Nios CPU frequency and how many MIPS does it show?
