14 years agotse transmission get hanged in TCP protocal
Hello,everyone! I want to transfer data between my laptop(the OS is windows XP) and my Stratix III 3sl150 board through ethernet wire. I'm using the hardware and software design found here...
14 years ago --- Quote Start --- Probably FIFO buffers are filled up... Nios is VERY slow doing ethernet data transmissions, especially when You use InterNiche and RTOS. Don't expect anything more than 10-15Mbps. --- Quote End --- Thank you for your reply, Socrates. For me,10-15Mbps is enough, but the speed is much slower than 1Mbps.(I'm using 1000Mbps & full Duplex mode). I ported Benchmark example in AN440 to this hardware design, and found the transmit speed is just 19k/s using TCP. And the transmission can not always get done(sometimes there is send() error).
